The ExtremeSwitching Universal switches can run two different operating systems: Switch Engine (default) or Fabric Engine.
*** 5520-24W Boot Menu ( 2.2.1.3 ) ***
EXOS: Default
EXOS: Primary 31.1.1.398
EXOS: Secondary 31.1.1.398
EXOS: Primary 31.1.1.398 with default configuration
EXOS: Secondary 31.1.1.398 with default configuration
EXOS: Rescue
Change the switch OS to Fabric Engine
Run Manufacturing Diagnostics
Update bootloader
Reboot system
Use the up and down arrow keys to select Change the switch OS to VOSS, and then press Enter.
Continue to log onto the switch (see Logging in to the Switch).
Caution
Changing your network operating systems deletes all configuration files, debug information, logs, events, and statistics information of the previous network operating system.
If you anticipate ever changing the operating system to Fabric Engine, and you want to statically assign IP addresses on the DHCP server, then it is recommended to assign them based on the DHCP client ID. For more information about this issue, see Using a BOOTP or DHCP Server.
Do not use the active, inactive, and partition options. They are not applicable for Fabric Engine.
